Reid Welch
double post in error
Reid Welch said:Matt: the controller as converter idea proved topheavy here;
I didn't find it stable-it's unregulatable as the battery supply voltage shifts during discharge.
Of course you're right Bob.
i wonder if you could teach my wife these words? i agree that if you need to control a few hundred watts a brushed speed control is a very cost effective way to do it, and if you wanted to control 4 auto headlights from a 48v ebike battery without connecting them in series this would be a cost effictive solution.
to control a single load of under 50w the simple switcher series by national are a quantum step forward in simplicity of design for an efficient low volume power controller that can easily achieve an output line/load voltage regulation of much better than a percent and requires only a couple of low esr caps and a high q inductor that will not saturate at the required current. Typical caps and inductors are $1-2 in small volume for a 50w implementation. 100 pc prices for components to produce a system that would drop 48v-15v@50W should be well under $10 including the LM2576
just a few years ago you needed a specialized ee to design a switching power supply, but now these chips have made it a job for a bright 6th grader. (too bad there do not seem to be very many of these running american companies these days). I have put together simple switcher supplies with inductors and caps out of my junk box that demonstrate that these ICs can handle a huge variety of components.
Switching power supply design was voodoo until just a few years ago for most of us. We can now take advantage of quantum performance level improvements at costs competitive with old school linear regulators, and the National "simple switcher" series is IMO the best place to get started for anyone who wants to use this technology but might have been intimidated in the past by the design calculations. These chips run at several hundred kHz and it is quite surprising how small the inductors and caps required to control a few hundred watts can be.
-bob
-bob
fechter said:This is the best one I've seen around lately:
http://www.thunderstruck-ev.com/dcdc.htm
There's some smaller ones here:
http://www.salvagetech.com/products.asp?cid=42
but most of these don't span the proper voltage range and the biggest ones are 20w.
bobmcree said:most of these converters can be fooled into producing a higher output by connecting a diode in series with the ground lead. then the output will be a volt higher, 2 diodes could give you a couple volts higher output
-bob
fechter said:bobmcree said:most of these converters can be fooled into producing a higher output by connecting a diode in series with the ground lead. then the output will be a volt higher, 2 diodes could give you a couple volts higher output
-bob
The units are potted, so digging out the epoxy isn't much fun.
I'd recommend the diode trick just to see if it works. The diodes might need to take a fair percentage of the output current, so they should be rated accordingly. If you put 3 or 4 diodes in series, you should be able to boost the voltage to over 14v.
rkosiorek said:most switchers use the ground or V- as a reference only. usually only need to pass 100 mA or less. 1A diodes should be plenty.
rick
