JRP3
Not to be Debbie Downer but I don't know how many "breakthroughs" I've seen over the last 20+ years that went nowhere. I no longer get very excited unless it's a shipping product.
BTW, this isn't exactly new, and I don't know where they got their cost estimates last time.3 D printing of dry cathode materials could dramatically reduce battery costs and allow better materials..
Sure, after many years of development.Well lately.. some of this stuff is starting to trickle down.
2:20 Ultrafast Laser Processing of Battery Electrodes for Faster
Charging and Improved Electrolyte and Electrode Wetting
Ryan Tancin, Staff Scientist, National Renewable Energy Laboratory
Ultrafast lasers can be used to create micro-structures in battery
electrodes that provide homogeneous wetting and greatly improve
high-rate charging. Our cost-analysis simulations using the Battery
Performance and Cost model indicate that adoption of ultrafast-laser
electrode processing adds minimal additional cell costs, approximately
$1.50/kWh. We present a detailed characterization of experimental laser
ablation for common battery electrodes, enabling informed choices of
laser parameters and accurate predicting of processing throughput.
Do we have news about announcement or upcoming cells that were unveiled at this event ? I can't see any recap on youtube or internet about this event.Here's something very nice for you all
Source: International Battery Seminar | March 17-20, 2025 | Orlando, FL
No sadly. Some of my friends were supposed to go there but sadly, due to rising US-Canada trip risks, they decided not to go.Do we have news about announcement or upcoming cells that were unveiled at this event ? I can't see any recap on youtube or internet about this event.
The combination of large format (4680) with tabless designs ( with their shorter current path) seems to have better energy density for a given chemistry than other cylindrical designs. More recycle friendly, easier/faster to make, and more electrolyte dense also.
Aluminium cans are the best for gravimetric energy density, but not volumetric energy density.The combination of large format (4680) with tabless designs ( with their shorter current path) seems to have better energy density for a given chemistry than other cylindrical designs. More recycle friendly, easier/faster to make, and more electrolyte dense also.
Using a cooling plate on the base (both electrodes on the top) offers better cooling potential than one sided ripple tube coolant setups as well. putting both electrodes on top and laser welding the conductors should ease assembling the pack.
Aluminum cans vs nickle plated steel? Some sources claim that as well, but I can't find a definitive answer. I would be nice to reduce the nickle used in EV batteries.
Can you elaborate on the reason for that volume reduction …With an aluminium can, you save a lot of weight, but you need to sacrifice a bit of volume for that weight loss.
For similar strength you need a thicker can with aluminum, and that takes up space.Can you elaborate on the reason for that volume reduction …
Evidently with the large 4680 format, you can lose a little volume to case walls and still improve volume/skin ratio over smaller formats. One of the papers I read mentioned specific high stiffness (or maybe tensile strength? ) aluminum alloys with deep draw capabilities..."hyperforgeable alloy "? maybe?For similar strength you need a thicker can with aluminum, and that takes up space.
Pop cans are supported by higher internal pressure which battery cells do not have. I am thinking more of structural 4680 cells such as Tesla uses, for non structural use it may not be an issue.Pop cans are already absurdly thin, after all, that tech is well established.
I can't find data on wall thickness for steel battery cans....what are they like?Pop cans are supported by higher internal pressure which battery cells do not have. I am thinking more of structural 4680 cells such as Tesla uses, for non structural use it may not be an issue.
Yeah, it's a great analysis.Nice comparison between BYD Blade technology and Tesla 4680. https://www.cell.com/cell-reports-physical-science/fulltext/S2666-3864(25)00052-9
You can see here that to achieve a decent range with LFP you have to combine both CTP design with stacking manufacturing process in prismatic format instead of using cheaper Jelly-roll winding, because you can get slightly better energy density by doing this. Samsung also do this in VDA-PHEV2 prismatic format 72Ah cell for Audi e-tron GT MY2025 facelift, older cells with 60 Ah was using jelly-roll.
But still BYD Blade LFP cell has only 355 Wh/l at the cell level, half of what you can get with modern NMC.
