monie jacobsen
- Joined
- Dec 28, 2016
- Messages
- 36
Hello YOU
Three Phase brushless DC-motor connect Delta with 4-Pole and 6-Tooth
Want guidance with winding stator please see below.
Would like GRUNDFOS ALPHA 2 to run on a solar cell with a maximum of 42V.
And want to use an ESC Controller to pump speed.
But after a lot of tests, I do not succeed!
Want to run pump the motor connected in DELTA.
Is there anyone here that will help with a drawing or description of how to connect stator as DELTA and the correct Phase and direction of the windings.
Regarding winding, I do not have the pumpe-motoren to run after repeated experiments!
Hope you will be helpful.
GUNDFOS ALPHA 2 - 4-Pole and 6-Tooth (Permanent Magnet)
De 4-Pole ses ovenfor!
With best regards
Monie Jacobsen
With best regards
Monie Jacobsen
