Cool strobe effect.
If you're seeing 82v without the BMS, then that would be close to the peak voltage I'd guess. That should be fine.
The charger behavior is a bit strange, and I could imagine that the off pulse might reset the auto cutoff if all the cells ever come up. My cheap chinese charger does a similar thing, but at a higher frequency. The auto cutoff works OK on mine as the charger maintains enough current to keep the control circuit alive.
You've discovered one useful feature of the BMS circuit by locating which cell is out of whack.
If that cell is damaged, it may never behave properly. Seems like a cell could easily go over voltage and fry without a BMS.
