Tony Shifter Kart with SIA 155-64 Hairpin Motor
Ciclon
🔌 New-ish
Gas engines is out.
E motor in.
Fardriver ND961200B_44 Controller (96V). Line 312A/ Phase 624A
Not sure if I will keep this battery set up. The Panasonic cells have a pretty high power output capable of putting out 200 amp bursts but each cell is only 5.5 Amps. Its a 30s. Might go with Molicel 21700 in a 28S6P configuration later on.
Throttle pedal is kind of clunky. Not sure how else I can put that on.
Initial impressions is that this shit is scary. A slight touch of the throttle will almost catapult the kart out of its stand.
Where can I find a good read on how to use the autolearn function?
IMG_20250601_123906.jpgIMG_20250601_123911.jpgIMG_20250601_123916.jpgIMG_20250601_123936.jpgIMG_20250601_124040.jpgIMG_20250601_124242.jpgIMG_20250601_124247.jpg
Nice! Have you driven it yet?
They might make smaller throttle pot boxes. Or you could mount it more in the center and extend the shaft somehow.
Not yet.
Need to do the whole autolearn thing first.
As to the throttle pedal if its just too odd to drive with I will look into other options.
Cool build, you can probably find info about the self learn in the fardriver thread: Nanjing far driver controllers
Otherwise there is probably something in my yamaha yz250f thread somewhere late 2022. I dont really remember myself how it was done, but I think you basically started it and held full throttle until it was done 🤔
...., but I think you basically started it and held full throttle until it was done 🤔
That is all you need for the auto learn. But afterwards the tuning for your desired Performance has to be done by yourself.
Auto learn sets only basic things.
Nice build you have there! For the throttle I'm going to install one of these: https://es.aliexpress.com/item/4001286165562.html
This box mounted behind the seat pulled by a standard kart gas pedal via a bike cable.
I'm saying this because I originally had in mind to install the same throttle as you, but I ended switching to the one on the link.
awesome , is that 0-5k Curtis pedal>? That's some serious power , 120 v times 32 amps =37440 watts,,, My kart is 26kw and its nuts.
Things have not been going well.
The controller wasn't working correctly so Alan sent me an updated .bin file. Took me a while to figure out how to get the fardriver app to ulpload the file into the controller becuase I lack Android competence.
I also left the ignition key on overnight and since I haven't connected a BMS the battery is now dead. I have a replacement at hand but I will get a BMS first before I swapp it. Tried getting an ANT BMS via Amazon and the seller never delivered. Should have just looked directly into their website as they sell them direct. Holly cow I am such a noob.
Oh well. Going to order BMS now and then replace battery.
