ayedurand
- Joined
- Jul 20, 2016
- Messages
- 10
So I have a bunch of 88509 batteries for Toro line trimmers. I'm planning on using them for ebikes for my nephews. I'm planning on running three of them in parallel (maybe four). They're 12s2p packs made up of Sanyo ur18650rx cells (attached). The battery pack has what appears to be a sophisticated BMS built into it (more pictures). I'd like to leave them as is and take advantage of someone else's engineering work.
I don't exactly know how LiPo batteries are managed. Meaning what is the key parameter that is monitored to ensure the batteries are not over charged. NiMH batteries had a voltage plateau and associated temperature rise that indicated full. So here's the trick there's a microcontroller on it that I "think" communicates with the charger. The chip that I "think" it talks to is a TS1102A that shows up in other battery packs for handheld tools but no one can find any data on. My fear is that this communication channel is going to get confused if I try to charge the three or four battery packs in parallel. Is this something I ought to worry about? Most tool battery packs have four lines connected to the charger or tool. I just don't understand why.
So, before I go and do a bunch of testing that others already know the answer to I thought I'd ask.
