spinningmagnets
100 TW
Lebowski, you sound like you understand this sorcery. If someone wanted a sine-wave controller, what would you recommend?
Saw that, partly liked it. My nits: Lite duty and not as feature rich as our common controllers.spinningmagnets said:Found this one in another thread, $86 shipping included...I just may have to try one of these:
http://www.aliexpress.com/store/product/ebike-sine-wave-controller/323339_694493303.html
That is the same controller I have except mine is customized for the integrated torque-sensor motor (see first post of this thread). It is a good controller, but you may need to buy the LCD display to go with it. I would advise emailing the store manager for more information - yonggang.lu@minshine.cn. Also, you may be able to negotiate the shipping costs down.spinningmagnets said:Found this one in another thread, $86 shipping included...I just may have to try one of these:
Nanoha, as far as I can tell my display unit works a bit differently because of the torque sensor and does not offer auto hall detection as an option. I am curious to know which motor is paired with your controller and if are you satisfied with the combination.Nanoha said:Yep, that's what I'm running. They modified it to work with throttle only.
Just curious Whatcomrider, have you tried auto hall detection?
I would if I could but am limited by the fact that there are a total of 10 wires running through the axle - yikes. I think my best bet is to find some wire with higher grade insulation. There are some detailed pics of the insides of the motor on page 1 of this thread that you may find interesting.dnmun said:maybe you can upgrade the wires with larger cable so it doesn't get so hot and replace the halls and try again. it would be interesting to see the insides.
Nanoha said:It needs halls to start up the motor. Once it reaches a certain speed, it goes into sensorless mode.
fabiograssi said:Did you try pedal first until reach something like 8 or 10 km/h and hit the throttle after that?
Pat, I highly doubt that the BMS S06S controller can be made to work on a motor without Hall sensors. Once you do install a motor with Hall sensors: if your LCD panel has the option of setting assist mode 6 it will work throttle only. In the other modes the throttle is inactive, and you will need to use a PAS to control the motor speed.patpatbut said:fabiograssi said:Did you try pedal first until reach something like 8 or 10 km/h and hit the throttle after that?
no I have not tried that. I did a test connection only.
controller +LCD panel + throttle + Motor + battery
For this setup it works fine for KU65 but not the sine wave controller.
Does this controller need PAS to trigger the throttle?
Pat
patpatbut said:Nanoha said:It needs halls to start up the motor. Once it reaches a certain speed, it goes into sensorless mode.
Hi Nanoha,
My motor only has three phases wire. Any chance I can simulate the hall signal without the hall connection?
Thanks
Pat
fabiograssi said:"Normally", sensorless controllers are "pedal first". I don't know how the ku65 starts the motor without initial movement!
Fabio
WhatcomRider said:Pat, I highly doubt that the BMS S06S controller can be made to work on a motor without Hall sensors. Once you do install a motor with Hall sensors: if your LCD panel has the option of setting assist mode 6 it will work throttle only. In the other modes the throttle is inactive, and you will need to use a PAS to control the motor speed.patpatbut said:fabiograssi said:Did you try pedal first until reach something like 8 or 10 km/h and hit the throttle after that?
Pat
BTW, Welcome to the Sphere!
Robert
Nanoha said:patpatbut said:Nanoha said:It needs halls to start up the motor. Once it reaches a certain speed, it goes into sensorless mode.
Hi Nanoha,
Thanks
Pat
If you're running an internal gear hub with a freewheel then you're totally out of luck.
The motor has to be spinning first.
I believe that is correct, Pat. I know that with my controller/display combo, which is made by the same manufacturer, the throttle and PAS do not work together.patpatbut said:hi Robert,
In that case, does this mean this controller would not work with throttle and PAS together?
btw nice to meet you too. Good to know this web site with so many experts here
Pat
crossbreak said:model S06P is sensorless but not square wave. It is almost as load as the normal KU63-65 controller from BMS battery.
crossbreak said:I have the "S-LCD" with the S06P which is produced by su zhou kunteng electronics http://www.szktdz.com/download/index.php
crossbreak said:These controllers are not really sensorless, too, they use an adapter inside the controller, that emulates Hall sensors. This adapter could be used with the sine wave version too I guess. The MCU is a CR8F612X 8bit one from ST. It uses one as the "brain" and one on the hall sensor emulator board. Guess they got a better price when they took 2 per controller![]()
crossbreak said:Max E-RPM wasn't tested yet. But I have porblems with the PAS behavior:
It accelerates sometime, sometimes not. A speed limit can be setup, but has no effect at all. It accelerates at 30kph, even if I set speed limit to 10kph. Battery gauge and ODO work fine. I use 12s Lipo (50V max) which may be a bit too much for the 36V rated controller.
crossbreak said:Ordered 5, did test one yet, maybe this one is just broken. Nice product if it would workI'll have to get hands on the xofo torque sensors, seems they are quite nice, thx for posting. Adding a torque sensor to a hub is just too obvious
crossbreak said:If this wont work i'll open a new thread... guess you didnt use PAS since you have a torque sensor. How is it connected to the controller? Do you have some wireing scheme? That would be highly appreciated! I searched a lot for a controller with torque signal input, sdaly there are only ones with 1.5kW and more. I'd like a 6-Fet with current mode/ torque mode throttle input to connect a torque sensor to it, sadly I can't find ANY. If these can do so, it would solve many problems of many people!
