Bamboo
If you have big windows to the south, you already know you are saving a lot on heating costs on sunny winter days, IMO. With this simple DIY system you can harvest the heat that doesn't come through your windows, but normally gets reflected/inefficiently absorbed by your walls:
On the Bottom there are holes drilled through the walls, same at the top of that "window frame covering the outside wall". The wall absorbs the heat (maybe use black stones - more efficient), the air inside heats up and goes up. Warm air is flowing into the house at the top part of the construction, colder air from inside is coming in from the bottom. The upper part with the open windows is for "warm enough now"-situations. If the sun keeps shining, it continously heats your house.
JM .02$
JM .02$
