kdog
Hi all
ive been playing with a 1200w microwave transformer to build a spot welder. learning as i go... in aus so on 240AC
i have a few questions that someone hopefully can answer ( ill have a crack- let me know if im even close
-The shunts (a bunch of lams) sandwiched between the primary and secondary coils. do i need to keep them? i read somewhere that they keep the power going through the primary coil down. is that the case? i figure that they shunt flux back to over the primary coil sort of like back EMF- is this correct?
if i took them out would it over power the primary when quiescent? or only when secondary is loaded?
itd be difficult to do so not real keeen...but if i get more power it might be worth it.
- does copper fill (like a motor winding) apply to the winding i put in? ( to generate as much current as possible in the secondary coil)- i figured it is exactly the same priciple so it should matter.
- why are the main lams seam welded together. i though the were sposed to be electrically insulated from each other. is this just cheap and nasty construction or is there something more to it.
im getting some welds happening so ill be doing a timer circuit next to help stop blowing holes in things!
anyway thanks for your input-
kdog
kdog
