ncwa
10 µW
- Joined
- Oct 29, 2011
- Messages
- 6
Does anyone have experience trickle charging / slow charging Headway cells? I have a 72V 40ah pack consisting of 96 H-38120S. When I charge with a 20 amp LiFePO4 charger, all of the cells reach approximately 3.65 volts in 1-3 hours depending on depth of discharge. However when I charge with my onboard 6 amp charger, only a few will reach 3.65 and the rest will stay around 3.50 to 3.54 volts even after many hours of charging. Some of the cells even seem to reach around 3.540 and then "rest" down to 3.520 while still being charged. While watching the BMS display, it almost looks like there are not enough amps to push all the cells to the full 3.65V. I have set my top end BMS to balance above 3.635 volts so I don’t think it is doing much with the 6 amp charger, but it is really working hard (hot) with the 20 amp charger.
Thank you for your help.
