VESC-based, capable of around 27s.
If for some reason someone advises against using a VESC controller, I’m also open to other suggestions.
You only really have a couple consumer options available for around these voltages, that would be
3shul (nice, vesc based, not too expensive for specs),
kelly (good all rounder, has variable regen)
sevcon (expesnive but good),
fardrivers nd96 and nd108 series (nd96s would work with 27s but not with 28s as the voltage limit is 115v but you dont have to charge to 4.2vs per cell, though do note that the nd108 series is basically vapourware at this point due to production issues, am expecting to see them in the somewhat near to mid future), and of course tronic.
The above mentioned ones will all run perfectly fine unless youre doing somthing like pushing the max phase or battery amps for a good amount of time and even then with decent airflow it shouldnt be too much of an issue, I dont have personal experience with the tronic but since its on the smaller/more compact side I would expect youd have to take a bit more care regarding thermals though, not much of a heatsink on there or material to move the heat away from the fets, that is probably why they recommend watercooling for higher currents, as already mentioned you shouldnt really have issues with any of the other controllers if they are getting decent airflow, but that doesnt mean you couldnt stick a coldplate on there if you really wanted.
:shrugs: no clue, its probably not terrible, again it is a very niche product and a small company, they dont seem to move many units
purchasing and delivery experience (currently, it's out of stock and delivery is expected in September),
Theyve been out of stock for a while, I was looking to order one around ~10/23 and they were out of stock with delivery expected around april, that eventually kept getting pushed back and Im unsure as to if they ever shipped that batch, to me it seems like a gamble if youll get it within the next month, or the next six months, if you get it at all :/
what continuous phase current can be expected with air cooling (Tronic stated 250A for the 30s version, but with liquid cooling)
I dont believe they list the phase current anywhere, the ~250-300 amps they list is I believe bA, taking a look at the fet datasheets and taking a guessitmate with the max lowside shunt current I would guess that its probably around 500 to 600 on the high side, I really wouldnt push it further.
general experience with Tronic, and so on.
Frankly Ive never even seen anyone actually pushing the x12 to anywhere near its stated limits, they mostly seem to be used in one wheels and scooters where theyre often limited by the battery, and tronic never replied to my email inquiring about some specifics.
If you want my two cents I would not recommend that you be the guinea pig for some still what is imo a experimental low production volume unit with basically no userbase.
I would recommend something from either fardriver, kelly, 3shul or sevcon (if you have the budget
) can say from personal experience that all four are very solid (ran a g4 550a sevcon and a kls96601 on my personal machines and played around/used/set up a nd96530 on a friends rig), and would very much recommend the 3shul cl700 for you as its based off vesc and a pretty decent controller, has held up fine so far. Also since you mentioned it in your question, there is nothing particularly wrong or bad about vesc, no reason to not use it if you have the option to, imo it is surperior to the software used by most other comerical solutions, as it is much less buggy than say fardrivers' or kellys' interfaces.
Appologies for the somewhat long, rambling post
, hope you found at least some of it helpful!
