Hello Forum,
i have bought are used ebike kit, unfortunately the seller did not have the pas sensor nor any documentation.
The motor is branded 'Plenty' and is made by Wuxi Truckrun Motor, 250w geared.
The controller is branded 'ZNZK Controller' 15A/7A product number ZN02-M6PLT. It has a wierd mix between normal sm and waterproof julet connectors (these are branded YLS but are identical to julet). The motor phase wires are separate with a separate motor hall sensor connector. There is a 9-pin Julet/YLS breakout cable conecting 2x brake switches 1x control unit(only 3 button + leds) 1x 3pin what i assume is throttle and 1x 2pin for light? The pas cable on the controller has a male end. There also seems to be a 4pin display connector. Although i dont know which displays could fit.
I can't find anything on the web on either the motor, nor the controller. I have ordered a pas sensor only to find out, that i cant connect it because it has the same connector as the controller.
How do i go from here? Is it safe to connect the pas sensor with some jumper cables to the other male connector for testing purposes or do i risk breaking the controller/pas sensor?
