Hi,
I have two folding bikes equipped with 36V 15A Lishui controllers, XMUS XF08 250W sine wave sensored motors and display from APT (UART protocol).
As I made new batteries with about 60A continuos discharge, I would like to power little up the torque to have more assistance on hills.
Asked XMUS local dealer how many Amps can handle the XF08 motor they reply that up to 17A peak will be ok.
I tried to do this via software by this method but I'm scared that the controller is read-out-protected and so will causes the firmware to be deleted.
So, may be hardware method will be more safely. I read that by lowering the resistance of the internal shunt of the controller the current limit will be increased.
As I would make a push botton in parallel with the shunt, my question si how thick should be the cable to lowering the resistance of the shunt so that not exceed 1-2 Amps power up.
Thank you
Thank you
