Turn My Transformer Spot Welder to DC using Kweld?
rg12
I have a pneumatic machine that I don't like it's consistency and how it's affected by different grids and sockets.
I want to have the Kweld connected to my pneumatic head and be powered from a big LA battery.
The question is, how do I take the output to the transformer or the signal to send power to the transformer and use it as a signal to fire the Kweld?
In my welder when I press the pedal it doesn't instantly power the electrodes but first makes the head drop and then fire.
Lead will need to be truly massive to output the current you can pull from a little LI pack.
Either there is a proximity sensor/switch that triggers the weld function when the head is lowered, or it is a timer with a set delay from the initial pedal action. Most likely a timer though.
I would buy a cheap timer circuit off ebay. Trigger it from the same signal running through the pedal. Use the output of that timer (probably a relay) to trigger the kweld. Discard/disconnect all the original controls, except what triggers/actuates the pneumatics.
A couple of decent sized car batteries will be enough power, and if you keep them on float charge, won't go flat. I use a single 750CCA vw golf battery on my diy welder. Works fine, but a second battery would probably be better.
afaik the kweld has an 'automatic' mode. it senses for a connection between the weld probes and fires a pulse when contact is made.
Perfect!
I guess this is how my current welder knows when to fire.
Wait, I know that those welders (probably Kweld amongst them too) fires on contact with a certain delay.
Can that delay be turned to zero? what is the range there?
EDIT: Can the kweld withstand an hour of intense welding? (let's say 3 welds per cell side for 300 cells?)
I see they sell this:
https://www.keenlab.de/index.php/product/kweld-ultracapacitor-module/
Will it make the Kweld better or worse for fast welding?
I see the cap bank is rated for about 2 seconds between welds which is very slow (at 50j which I have no idea how strong it is).
Also, if I use a car battery, what is a good size for it? Can I get away with 50Ah? and can it be charged while in use or will it blow my charger?
You just need a good battery that has a good CCA rating, myself I use a 8 year old 27ah fullriver fullthrottle agm battery to power my 12 volt malectrics, it works excellent. I tried using a 4s8p lifepo4 (A123 cells) and also a 3s6p li-ion(using sony vct3 cells) and all I got was weak welds. The fullriver never fails, I also use it to jump start a V8 carburetor engine using fullsize 10 foot jumper cables. I prefer using the agm because I weld inside and don't want any acid leaking etc.
As far as charging it, you can do hundreds of welds without draining the battery too much, after using the welder I rarely have to put more then 3 ah back into the battery. No need to keep the charger plugged in while in use.
Thanks alot!
