wesnewell
I've got a 14s pack configured 5s+4s+5s and I want two 7s balance cables instead of the three.
First 5s brick cells Middle 4s brick second 5s brick
+1-+2-+3-+4-+5- +1-+2-+3-+4- +1-+2-+3-+4-+5-
For the first 7s balance cable I wired the first 5s brick balance leads straight to the 7s connector, then from the 4s brick 1- and 2- to pins 7 and 8 of the 7s connector. I tested this and the first 7 cells show up fine. Now I assume for the 2nd 7s connector I need to split the 2- wire (or +3, depending on how you look at it) of the 4s brick and take it to pin 1 of the second 7s connector also, and then continue on down with each cell skipping the +1 of the second 5s brick and ending with 5- as the last connection.
Anyone see anything wrong with this? Looks right to me but thought I better check to see if there's something I'm missing.
