marty
🏍️ Giga poster
Stan's is latex and ammonia based. It congeals and turns into weird rubber "stanimals" inside the tire. It is one of the reasons I tell people that tubeless conversions will absolutely waste more of their time than if they fix flats as they occur.Hey, that's another one I didn't know about, just like that Joe's stuff. I see it says you need to add more sealant after 2 to 6 months, or whenever it looks like it needs it.![]()
That's what seemed most likely to me, but I wasn't exactly sure how it's usually done at home. You do give up some convenience when the motor is still tethered to the deck, and there's also the risk of pulling or straining the cable, so I'll be careful about that. I'll also make sure to raise the deck just enough to give myself the necessary clearance, which certainly wouldn't hurt.Is a connector needed? As long you can drop the wheel out of the swing arm, it doesn't matter for tire changes if one side still has a cable coming out it, right? You only need one side of a wheel to be open to remove/replace a tube/tire.
This is very good design, as it prevents axle from moving/slipping in the dropouts.I also need to loosen those two bolts that clamp the swingarm to give it the opening that will free the axle.
That sounds like a good idea. I could lay a bath towel on the floor and lay the scooter on its side. Another option is to rest the deck on top of a plastic milk crate and place a second crate next to it to support the wheel. I have several of those crates—they're very sturdy and work great for this kind of job.If I was doing this tire change, I'd lay it on it's side. No chance of it toppling over.
Disconnect wire so that when tire falls out it don't rip and destroy wire.
Disassembling/ reassembling over a towel has the added benefit of containing any small pieces that spring out when opening up a mechanism. Much better than ball bearings, washers, springs, etc. bouncing and rolling all over into unfindable territory.bath towel
I see. Then I'll keep using the milk crates—one to support the deck and another next to it to support the wheel once it's removed but still connected, so I won't have to open the deck. It all comes down to being careful not to let the wheel drop when I open up the swingarm.. Haha, it's actually almost at floor level, just a couple of inches.Disassembling/ reassembling over a towel has the added benefit of containing any small pieces that spring out when opening up a mechanism. Much better than ball bearings, washers, springs, etc. bouncing and rolling all over into unfindable territory.
You know you can put tubes in tubeless tires, right?The tire is tubeless and only has about 80 miles on it. I think I may need to replace it because the damage it suffered was quite significant. Even if the Slime seals it for now, there is still a risk that the cut could eventually reopen, making the tire less reliable. Of course, I could also try patching the tire and installing an inner tube, but I'm not sure what I'll do yet. Looking at the prices of 90/65-6.5 tubeless tires on Amazon, which are around $30, I think I'll just go with one of those.
Edit: I just took another short ride a few moments ago to see if the Slime had stabilized the puncture, but things went badly. I went from 45 psi down to 20 psi. At times it was making a loud noise, like spraying a can of compressed air — pshhhhhh! This tire is basically a lost cause.![]()
yes I know, but once a tubeless tire has suffered a straight half-inch cut, it's no longer a good candidate for installing an inner tube. Even if the cut is patched from the inside, that damaged area can still flex under load, and over time the sharp edges or weakened casing could pinch, chafe, or even puncture the new tube. A repair might hold for a while, but there's always the possibility that it could eventually fail. For me, a cut that large is a good reason to replace the tire rather than trying to squeeze more life out of it.You know you can put tubes in tubeless tires, right?
Does it stick to rubber? Try this.5-minute epoxy
Try a Tire Shop. They will put a plug in tire. Done problem solved.smoke shop
Please make video of tire changing episode. Should be more entertaining then cage fighting on white house lawn.My new toys should be here in five days.
Sure thing!Please make video of tire changing episode. Should be more entertaining then cage fighting on white house lawn.
