Brake sensor, controller thinks brakes are on, have you been in the rain? Assume you have a KT controller, follow brake sensor wires back the controller and unplug see if that clears the problem also have you lost a sensor magnet or has brake sensor moved if they are stick on. Unplug one sensor cable at a time to see if the brake icon disappears then you will know if it's the front or rear brake.
