Doctorbass
The Cherokee International CAR2548
This part number is the one of one of the highest power density of all 48v psu existing actually.
It have 27W per cu3
the most known we use have about 19W/cu3
It have 1.6" x 4" x 14"
it is about twice smaller than the ESP120 and have similar output. The ESp120 have 21 inch long!!! but the CAR2548 is only 14! that's 7 inch less!
it's the same brand as the CAR1248 known to be used by the Russian for the Adaptto.
And yes! if you have enough current on the 120V or want to use both outlet in parallel you can use then with the 120V !
(90-264 VAC, 47-63 Hz)
By comparison the ESP 120 is only 190-240V.
and It is just 4.73 pounds.
Here is the datasheet: http://pdf1.alldatasheet.fr/datasheet-pdf/view/408715/LINEAGEPOWER/CAR2548FPB-1A.html
Doc
It have 27W per cu3
Doc
