dannydibbert
- Joined
- Nov 22, 2021
- Messages
- 18
After all my troubleshooting to find the somewhat random weird grinding noise at high wattage (~900+ watts) on my new e-bike including a Bafang 750 rear hub complete tear down with magnet inspection, nylon planetary gears relube with red lithium, spoke checks, controller evaluation, elimination of brake possibility by riding alternately without front then rear, lots of Q/A on my thread below which all helped a bit; the grinding noise still occurred (not quite as bad but still there).
I took a step back and considered that the issue, since it is not repeatable without a load (i.e. upside down there is no issue ever), may be a dynamic resonance issue somewhere. Realizing that the most likely part susceptible to this may be the spokes I refocused on them. It turns out that my front and rear spokes have a very cheap reflector set. I removed both reflectors and did a bunch of repeated high wattage riding and wouldn't you know it ...... NO MORE GRINDING NOISE AT ALL !!!
Thanks again to all the help on this forum.
https://endless-sphere.com/forums/viewtopic.php?f=3&t=107515
