double_wide_suprise
Hello everyone at Endless-Sphere. Just wanted to say first and foremost how much I appreciate all of you for the knowledge that I have been able to gain just from reading through threads. I thought it was a good time to make my first post with an issue that I’ve been dealing with for almost a YEAR. I’m copying this post from a FB group as it’s a little long to re type out since I got no luck there. And it’s worth reading. I’m not inexperienced either in electronics or the sort. If anything this is more of my wheelhouse as I work with brushless motors a lot and build packs.
Something to note that may be the issue is either throttle and issues with the hall, or what I truly think it is is the joining harness that connects both controllers as “one” also on my brand of “5600w” Chinese scooter, the stock controllers are yunli, and do not have markings dictating an master or slave controller. And I proved this by swapping as you will
Read.
Post:
I bought this scooter a little under a year ago. It’s relatively the same as all the other “China” scooters. You can find this same frame and layout under many different names. It’s a 60v 5600w dual motor variant like most 1500$+ models. It comes with the same generic 60v 45A controllers with a harness to join them.
Thought I’d put that description out there for reference. To possibly help. Also im electronically inclined, and knew buying one of these was going to take a lot of DIY for maintence and diagnosis which is no problem as i am particularly experienced in BLDC motors and comteollers. And i like to think im fairly inclined in sourcing parts and schematics given these things are a PITA to find info on. Searching through aliexpress takes a language in itself lol. Even with my pretty extensive background, im STILL stumped on this issue. But with that said, any kind of ideas you guys might have, I’m not afraid to try and throw my meter on.
My issue is regarding throttle response. Particularly in single motor mode. And this issue persists through all 3 gears. (My model only has the three gear option). If I give it full throttle from a dead stop, the acceleration is very hesitant and “jerk” like. Not violent but almost like a car with misfiring issues. Best way I can describe it is like I’m metering my throttle back and forth from full the half. And continues this kind of “jerk” motion till it reaches speed of whatever gear I’m in. And to add the acceleration is very weak. Even in gear 2/3. It’s the same for all three.
Here is the weird part, when I put it into dual mode, it’s totally different. The scooter responds way differently and accelerates WAY better. But I notice the front motor seems to get more power. It will actually lose traction and such because the power is so much. And I can tell the rear motor is giving more power but still, the front motor is putting out way more power. Now this may be all in my head as more weight is on the rear motor but worth putting out there.
So naturally I tried a couple different things, first I was able to warranty a brand new motor. So I installed that. Then to try and prove my point more, I swapped the controllers around to change what’s controlling what. So I changed I moved the controller that was originally controlling the front to the rear, and vise versa. I did this to see if maybe it’s one of the controllers acting up.
So, brand new rear motor, controllers swapped around. All “P” setting correctly set in my throttle. (TF-100 type), hall wires and everything connected correctly, and a new learn procedure for the motors. Should at least prove my theory that the controller giving power to the front originally was performing better right? Wrong. Same thing. Rear motor seriously lacking in power no matter what, and very hesitant acceleration.
So the only thing I can think may be causing this is either, the harness that connects the two controllers into “one”, power is actually limited to the rear in single mode, or my throttle is acting up. Maybe the hall sensors inside the wiper or something.
I’ve dealt with this since only a month after getting it. Every thing else is great, it’s just I would actually like to be able to use single motor mode from time to time because right now it’s not really that usable.
Sorry for such a long post but the details are important.
Read.
Post:
