mjp8081
I have an MBS board with some older e-Glide GI parts, basically:
36v LiFePo 20aH
wired gun controller
800w single motor mounted to a GI rear truck
(http://www.e-glide.com/electric-skateboards-store/electric-skateboards/gi-powerboard-detail)
I want to change to 2wd, and try to reuse the parts I have and keep the torque and speed--to something like this: https://www.youtube.com/watch?v=NzPsFwT2iDY
When I looked up these motors on HobbyKing (SK3 6374 - 192 kv), I am a little confused by the voltage and watt/amp rating. Are these a newer technology of motor that accepts a wider range of power?
Can I split the 36v output from the speed controller and use these kind of motors? How do I tell if I'm getting the equivalent of 2x 400w motors?
Also, by pushing forward on my trigger controlled SC it has "braking", by reversing the polarity a bit to slow down--does anyone know if these motors work with that functionality?
Thanks everybody! Also any links to custom parts makers like motor mounts would be appreciated.
36v LiFePo 20aH
