iovaykind
Okay, so I'm on my first charge cycle and I already can't stand how slow charging at 50w is.. my 10x 4s1p 5000mah hardcase packs need something juicier and I need to save time, not so much money in a case as extreme as this. It should take about 8hrs to fully charge the packs, I want to cut that time down to 2-3hrs. I've looked into alternatives, which I should look into? I still want to save money and not spend a crazy amount on a charger, but if I can get away with charging in 2-3hrs, that's a lot less monitoring time than 8hrs.
Also, in the event OF a fire, what do I even do? I'm watching the charging but I'm not sure I would even know what to do if a fire started other than try the fire extinguisher (is that even a good idea for lithium fires)?
