dnmun
1 PW
from your diagram, you have assumed that because the total voltage across all 4 of the cells is 16.4V then each cell will be limited to 4.1V. that assumption is wrong. the individual cell phone chargers do not have a way to stop the cells from being charged above the 4.1V level because there is nothing that can drain off the current flowing into it from the bulk charger.
if you had a balancing element, on each cell, that limited the voltage to 4.1V then you could manage to balance the pack very fast this way. but your balancing element would have to be capable of draining the amount of current being pushed by your bulk charger.
it would be more effective to turn off the bulk charger immediately when one of the individual chargers reaches the 4.1V endpoint. that would be the most effective control.
you could do that by having an opto isolator chain driven by the individual isolated chargers, and when one of the chargers signal endpoint, then you can take current for the opto isolators from the op amp inside then you could use that op amp output to turn off the bulk charger. you could even use the opto transistors to control the internal circuits of the charger so it would be done electronically and not by a relay type switch. that way the bulk charger could be active and when you swapped out the charging cell the bulk charger would reset and start charging again, until another of the cells in parallel would reach endpoint. then when the led went off and the bulk charger turned off, you could pull the cell out and put in the next one.
have you taken apart the cell phone chargers already? the opto transistor is along side the transformer, the four legs that cross that electrical isolation gap between the front end and the back end of the cell phone charger?
