Sandroforms
- Joined
- Jan 8, 2023
- Messages
- 39
Guys, I made a display project to be used with VESC, using an ST7735 display connected to an Arduino Nano, and in this Arduino, I also used a KY003 Hall sensor, to read the speed of a rear wheel of my bicycle, the display shows the speed of the rear wheel, the temperature of the motor, the controller, and the battery charge, but I'm having some problems that must be interference, could someone help me? I used the TX, RX, 5V, 3V, GND and ADC1 pins of the VESC COM port, to obtain the VESC reading, and also to use the accelerator, but when I activate the accelerator, random numbers appear on the display, and it ends up interfering with the data, would some type of hardware be necessary to avoid this interference? I heard that it would be necessary to use a filter on the vesc to use the correct tx rx data, what would this filter be like?
