MitchJi
Hi,
The surprising thing is after repeated piercings, or the corner being burned off with a torch it still works (charges and discharges).
[youtube]Jz37WycW-7E[/youtube]
A used battery from a Nissan Leaf 3.8V 33Ah, tested for how likely to catch fire when is destroyed or in flames. We had no success make it burn. Same battery after the burn test was charged/discharged twice at 1/3C - 10A - it has 30Ah capacity remaining. Before the test this cell was under salty water for 2 hours - you can see the contact are destroyed.
When pierced through by the flat head tool, there is no explosion or eruption of flame. Instead, a rather modest wisp of smoke shyly emerges as the electrolyte next to the shorted area of the fully-charged foil pouch reacts with the influx of oxygen. Again and again, the blade descends, until the cell is riddled with holes. No fire.
Amazingly, when connected with a voltmeter afterward there are still plenty of signs of life, and when it is charged and discharged, it suffers only a slight loss of charge capacity. The video goes on to show another cell attacked with open flame (with a propane torch) with similar results.
