nyebi
New here
Hi!
I recently bought a Volta VS1 e-scooter ( https://www.volta.com.tr/en/product...8Qzt9M7F_YMGJSdKydC_dlW_EA00qkO0wwKPmBDVxqNAb ).
It has 5 12V SLA batteries connected in series, a supposedly 1,5kW rear hub motor and this type of controller:
Apparently it is sold by Chinese vendors in many different variants (multiple voltages and motor power) with multiple different stickers, but the layout and the pins of all of them seem to match. Example.
But I couldn't find anything more than simple wiring diagrams about it. It looks like it does not have the wire loop to be cut to remove the limit like many others do. None of the similar topics in this forum seem to be about this controller either.
The factory speed limit is 45km/h. The scooter won't go any faster, even down on steep slopes it will limit itself to this speed. I double checked it with a GPS tracker, 46 km/h was the absolute maximum i ever got. There should be some spare power in it because when it is climbing a slight slope upwards it can still reach the 45km/h limit.
If anyone knows this type of controller, is there a way to remove the limit, either by HW modification or hooking it up to a computer to modify parameters?
One interesting side note: the VS1 seems to come in two variants, the other one having a 25km/h speed limit. When I went into a shop for a test ride the clerk said they only have the 25km/h variant at the moment, but after I insisted to try it anyway he did something with the speed selector switch, the park switch and the throttle (the whole thing took like 2 seconds) and proclaimed that it is now the 45 km/h variant. So either the controller has some hidden magic combination to change parameters or he just tried to cover his previous lie about which variant it was.
