voltage doubler (diode/capacitor method)
ejonesss
http://en.wikipedia.org/wiki/Voltage_doubler
i know that using transformers and dc to dc converters there is a volt/amp tradeoff just like there is a resistance/wattage tradeoff when seriesing/paralleling resistors
i was wondering if you take 3 volts 15 amps ac then feed it into a diode/capacitor multiplier network is there any tradeoffs there meaning is there a loss of amps on each diode/capacitor multiple?
i am thinking about building a battery charger to charge lithium batteries based on a microwave transformer i have cut off the high voltage side and re wound it with 3 turns of 3 conductor 12g household wire that will make 3 3 volt ac at 15 amp and then using diodes and capacitors make it to 3 6 volts or even more and then use dc to dc converters to do the regulation of the power to the cells?
Its very lossy, especially at low frequencies.
I'd be winding more turns onto the transformer.
i was thinking the trade off where to get 1 amp at 110vac you have to draw 10 or even 100 amp on the input.
because the ac is being converted to dc and make a + and - voltage a split power supply sort of like you see in many sound systems where there are 2 large capacitors
i know the dc to dc converter is going to be lossy but my main question is if there is any trade offs by seriesing a bunch of transformers if there would be the same loss idea like you see in seriesing capacitors?
Watch out for microwave oven transformers. They're only designed to run at full load and will overheat otherwise:
http://sound.westhost.com/xfmr2.htm#s16
Voltage doublers don't perform well at high currents. With more multiplication, you get a very high ripple on the output.
I'm not sure I follow about series transformers. The old fashioned way is to use multiple secondary windings or a tapped secondary. If this is all running at 60hz, you need a big chunk of iron to make it efficient.
