- Joined
- Feb 15, 2013
- Messages
- 1,903
voltz-bikes eTrail uphill downhill ebike: http://www.voltz-bikes.com, https://www.facebook.com/voltz.bikes
[youtube]4TqfWl6aY1Y[/youtube]
Looks nice! However... price?
Built to order electric mountain bike made in England. This is a pre-production model that we are currently testing. Final design to be confirmed. Built by a small team, using the best materials for weight and strength, incorporating carbon fibre,titainuim and 6000 series billet alloy cnc machinened and TIG welded. Total bike weight 19.5 kg. We use 3D computer drawing to get the best design and engineering solutions. Available late 2013.
50/20 model powered by a 3000 watt max, 2000w continuous mid drive system, running back to a 9 speed XTR rear cassette allows for maximum torque and high speed.Battery performance is deliverd by a 50 volt lithium polymer 1 kwh pack, through a smart controller and analysed during riding by the bikes computer.The controller can be set to suit british legal limits for electric bikes with the supplied software, and the onboard computer can be set on the go for speed,watts,amps and battery regen.Re charge time 2 hours using the smart charger supplied. The bike tested on gadget show, 50-10 uses a 1500 watt motor and a .5 kwh battery with a range of 25 miles. Bike weight 17 kg.
This bike has been designed for cross country or all mountain riding, but works equaly well as a day to day mountain bike. As it will be built to order, component specs can be down to customer preferances,price's will vary. Call Jeremy for more info.07966625084.
efMX Trials Electric Freeride said:Voltz E-MX shakedown with 2 stealth's and a Volts E-Trail:
