Got a 36V, 30 amp Infineon controller on a 15ah Ping with an Evtech BMC 400w hub and when I first turn it on it sounds like a sick frog and then cuts out to no power.
I crank on the throttle and it does it again. After doing that around fifteen or twenty times it stops malfunctioning and works perfectly and will continue to work fine for the rest of the ride, however long it is.
It sounds as if one of the phases is not getting power and it takes the controller a bit of time to warm up until it works.
It doesn't matter if the battery is fully charged or not; not voltage dependant IOWs. Took apart the BMC hub and everything looks perfect.
Anyone else have similar relationship with their machine?
Bought it from ComCycle who I have not had the best of luck with.
