ibra2672 said:Noob speaking here.
What determines torque? Is it the wattage, voltage, amperage or structure of the motor?
Does overvolting a hub motor increase its torque?
Does changing the controller for one with higher amperage increase torque?
ibra2672 said:Thank you very much for the replies!![]()
If I may ask, what are phase amps? Is it simply the current flowing in the phase wires of the controller? Or is it the maximum current that the controller can supply to the motor?
Danishblunt said:These things have the highest impact on torque:
- amp provided by battery/controller
- Wheel size
this is why bikes with very small wheels have typically very good torque.
Chalo said:Danishblunt said:These things have the highest impact on torque:
- Wheel size
Nope. Torque is independent of wheel size. The same torque does different things in different size wheels, but it's the same torque.
Nope. Torque equals force times radius. Changing the radius changes the force inversely, but doesn't affect torque.
