I wouldn't be too concerned about gear wear & tear: as far as I know the gears should be very durable & require minimal maintainance (at the standard 36-40V and 16A limit at least), like regreasing after 10,000 miles I think? However, there is
some freewheel resistance, due to the gears, but it is definitely minimal & I don't mind riding it with little or no motor power from time to time
. I don't know, but I'd be surprised if ungeared have motors have
more drag? The bike you posted about
may have a similar motor to the original Torq motor (doesn't look identical though) i.e. geared, but thats one of the first things I'd ask about, and their ease of freewheeling or pedalling without motor power can vary a lot.
Noisewise, at speed I'd say my Torq motor is barely louder than some rather noisy knobbly MTB tyre 'hum', or a quite loud old-fashioned friction dynamo, if you know what I mean
so noticeable on a quiet road, yes; intrusive, no; silent, no; audible in traffic or moderate background noise, hardly at all or no. The motor in the Ezee kit & on the new Torqs is an upgrade and may well be quieter - now Ypedal has one too, there might be more feedback & info soon
. I'm also sensitive to noise and while I'd prefer it to be silent or virtually so, I don't find it a problem since its good motor for my needs. An absolutely silent hub motor would be noticeably quieter though, for sure, except on quite busy roads. On the flat, you can use a non-geared almost as easily & they're likely to be quieter I think, but others will know more on those
. The light weight of geared hubs is nice though! To be honest, I don't use the full acceleration of the Torq either, and pedal from starts with gentle throttle to increase the range per charge, so you might end up doing the same as you would with a non-geared anyway! But the geared motors are a blast to ride - look at knoxie's posts re the puma! and the speed of the Torq is plenty enough for me
From discussions of ebike prices here in the UK, the concensus seems to be that you pay extra for quality parts & construction, research & design investment & good support.
PS If you're really after a bike which freewheels with virtually no drag, is virtually silent & can give its full power in any gear, plus fully waterproof & 2 year guaranteed lithium battery, check out the likes of biketec & kalkhoff which use the newest version of the panasonic unit which was used in the Giant/Lafree Twist
. Check your budget first though
