What do you think of this tyre?
patrickza
Marathon XR HS 359
http://www.schwalbetires.com/content/title-8
My requirements, in order of importance:
-Puncture resistance
-Durability
-Grip
-Rolling resistance
I spend most of my time on the road, but occasionally head for a dirt road, very seldom though. More common is dirt on the tar road. If it rains I usually take the car.
Now the big catch for me is that the rim on my 5305 seems to be slightly right of center when sitting on the bike. When I put my continental 26x2.3 knobby on the back it rubbed on the swingarm. Swapped it with my front tyre which is a 26x1.95 knobby and i have about 2mm to spare. So anyone want to hazard a guess if the 26 x 2.25 in this style will be narrower at the extremes than a 26x1.95 knobby. The profile looks quite round compared to a knobby's square profile, so I'm hoping not.
If only they had them in a 26x2.0 but it seems not. I guess I could always try one and if it doesn't fit save it for my front wheel and get something else for the back...
Based on all the tires I've had of various sizes and types off scrapped bikes, if it says it's a wider tire then when it's inflated it will be. :( Most likely if the tire you're looking at is wider than a tire that would barely fit then it probably won't fit once inflated.
It depends on the rim it's on, though, since if you mount a wider tire on a narrower rim than it was meant for (if it has a good enough bead to stay seated despite this) then it may make it narrow enough to fit anyway.
(note: the stuff below is largely irrelevant but I started typing it up and got sidetracked, was done before I realized how far off track I got; seemed a shame not to just submit it anyway. :( )
I had a lot of trouble finding tires that would work without rubbing on CrazyBike2's rear stays, in any wider tires, even though I was using 24" tires on a 26/27" frame, because the frame had been meant for pretty narrow tires (an old Schwinn 10-speed).
What I ended up with that is really the widest that will work without rubbing on one side or the other is very like this:
http://www.choppersus.com/store/product/290/Tire-24-x-2.1-Skinny-Cat/
that originally was a front tire off the Schwinn chopper ebike that has that plastic fake ICE in the frame and an IZIP (I think) e-drive.
http://www.evalbum.com/1375
I got the tires from All Electronics, of all places, for like $7 or $8 each incl shipping for four of them.
A bit more looking and I found the original item; looks like they still have some but the price went up from $5 to $8, not including shipping:
http://www.allelectronics.com/make-a-store/item/BTR-24/24-CHOPPER-TIRE/1.html
