dgk02
I have a cheap q100 front wheel kit and a 36 volt 15ah battery. It works fairly well. What does a Cycle Analyst do? Does it replace the controller or give me a better indication of the battery charge? The charge indicator on the battery broke a few weeks back (the two high LEDs aren't really working so it only shows at best half charge). That isn't critical since a 1/2 charge generally gets me the 30 miles to work and back. The indicator on the little computer thing (which has the power button and low/medium/high switch) always shows full (four lights) because I think it was designed for 24 volts and I'm running 36.
I was wondering if a CA will get me better control over the assist levels and give me a better idea of what is going on in the system.
I have had a problem the last few weeks with the motor intermittently cutting out - I can feel it but it usually picks up again. I think I fixed that, it was likely one of the three motor wires that seems to be making crappy contact with the controller wires - there's a black burned area in the connectors. I'll know later today when I give it a good test ride. But I was thinking that it would be nice to have a better idea of how to troubleshoot. The problem could also be the battery connections to the controller; it's sort of hard to tell what's going on sometimes.
