What is Tennessee Law Regarding my E-bike
knightmb
Franklin, TN
Basically, you are free to ride it without registration or title as long as it's electric and NOT gas powered. You must where a helmet at all times and those under the age of 16 must get a permit to ride. You do need a valid drivers license though (the same one you get for your car will work). I got this information straight from the DMV managers.
what about gas generators?
can you set up your bike diesel locomotive style?
trains use the fuel to generate the electric to run the train the drive is electric so if you can take one of those portable camping generators.
http://cgi.ebay.com/RAMSOND-3200-W-INVERTER-PORTABLE-GASOLINE-GENERATOR-RV_W0QQitemZ150292726341QQihZ005QQcategoryZ106437QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and then a power transformer to reduce the voltage to what ever your bike uses (if it a 48 volt system then you need 50 volts at 40 amps then convert the ac to dc to run the bike or charge the batteries.
another option is a small engine to run a car alternator wired to what ever your bike uses.
the thing is i am not sure what the law is looking at if it is the pollution,noise,fire safety,range to determine legality.
