CUDAcores89
1 W
- Joined
- Aug 28, 2016
- Messages
- 51
Today I decided to open up my "500w" ebay hub motor to coat the stator in some SPRAYON EL601 to waterproof it. I live in Michigan, so water getting into the motor is a real concern. But while we are in here, I would like some feedback about what kind of motor this actually is. Is this a 9C, golden motor, or some generic thing?
A little background on my bikes specs:
52v 20AH battery built from old power tool cells.
Gary fisher mountain bike
36v "500w" ebay hub motor kit.
With zero modifications to the wiring, I currently run this hub motor at 1500w continuously. I performed a shunt mod on the stock controller to get me 30A and replaced the capacitors so I could go to a 52v battery (FETs were already rated at 75v). So far i've done a few hundred miles on 1500w with no ill effects as far as I can see.
Anyway here's what we got. The hub motor has written on it "9x6" and "12" (or is it 9x6 and 21?). I'm not sure what these numbers mean so enlighten me.
First the link to the ebay page:
https://www.ebay.com/itm/26-Rear-Wheel-36V-500W-Electric-Bicycle-Ebike-Conversion-Kit-Hub-Motor/321679232957?epid=1580882108&hash=item4ae5938fbd:g:OikAAOSwb9BatNFP
Pictures:
Questions:
Since I have been running this motor at 1500w, how far do you think we can go? Could I possibly run this hub motor at 2000 or even 3000w at 72v if I drilled holes in the cover places or added statorade to the motor before i close the thing back in again (I can't do both because then the statorade will just make it's way out through the holes)?
Also which is better for cooling? Statorade or drilling holes in the cover?
Since I already have the motor open, I would like to beef up the phase wires to 12AWG and add either statorade or vent holes Just in case I want to run this thing at even higher power later on. Knowing me, I probably will inevitably do just that, so might as well prepare for the future now.
One more thing:
I believe statorade is just ferrofluid. Couldn't I just buy a can of ferrofluid from amazon for less money than the statorade? It seems like it's the same thing.
https://www.amazon.com/CMS-Magnetics-Magnetic-Ferrofluid-Projects/dp/B000VAZKQI/ref=sr_1_fkmr0_2?s=industrial&ie=UTF8&qid=1525505850&sr=1-2-fkmr0&keywords=10mm+ferrofluid
Pictures:
Questions:
One more thing:
