voicecoils
Excellent, that's what I was hoping to hear.fechter said:You can change the timing for operation in either direction (relatively easy).
Yes, you will need a humongous rear sprocket to do a single reduction. It will be more reasonable to use a double reduction so the sprockets don't need to be so big. This usually means using a jack shaft of some sort.
I agree single reduction is starting to look quite unpractical. The link I mentioned a few posts back: http://www.peltzer.net/ebike/index.html shows a guy with a less powerful motor then the magmotor but similar form factor and high RPM. He's gone through a number of revisions and ended up on a double reduction drive, first belt, then chain.
version 1.0
version 1.3
version 1.4
version 1.5
