My cranks have some play in them, looks like the shaft in the bottom bracket is the cause. I'd like to open it up to check the bearings. Any idea what tools I'd need?
Obviously an 8mm allen wrench which I have, then I'll need a crank puller which I should be able to find, but lastly I'll need something to undo whatever you call that pieve with all those grooves in it. Any ideas? And will the other side be the same, I can't see past the sprockets. The cranks have TRUVATIV FIVE D written on them if that helps. Pic below.
