tiagormp said:
Yes, bike is complete and I've been using it for quite some time with no issues...
I"m assuming "complete" means just the bike itself, not the electrics?
Do you have anything electric other than the motor already?
What connector does the motor have on it? This will help us help you find one that has the right connector so you can just plug it in, if possible, or if not, an easy-to-install set of connectors for both motor and controller.
I'm looking forward to get this bike converted to commute to work mainly, It's pretty flat where I live, so.. I'm ok not having a super strong motor or a really large, heavy battery... I was hoping to have at least 25 km range with a single charge and as I said before, I'm looking for the most simple setup possible. there are so many controllers available and I'm not sure what I need to make the motor running.
I really don't have a budget, as this is my first ebike conversion, I would say I'd like to spend as little as possible and hopefully I would invest in a better setup, once I've learn a bit more.
OK, if it's pretty flat, and you don't have any speed you need to reach beyond typical pedal speeds (presumably, usually around 25km/h or less), then the only two big limiting factors on what to get are the battery capacity to reach that 25km range, and something simple that doesn't require much setup or a lot of stuff to put on the bike to operate it.
The simplest systems don't have any display, and so have no settings or levels to the assist--you control them entirely by the throttle. Motor configuration on them is done via "learn" wires that you connect with the wheel offground, wait for the motor to spin the right way, then disconnect and leave that way. If that sounds like what you are looking for, then we can poke around to find one of those, once we know what motor connector you have and what else electric you've already got (and what connectors are on them).
It's pretty likely that that motor will do 25km/h (maybe a little more) on 36v, if it's in a 26" wheel. (a smaller wheel will be slower). 25km/h should take around 20wh or less per mile, depending on conditions and whether you help by pedalling or not. It may take much less, perhaps only half that (my Crazybike2 only took about 20-30wh/mile to go 20mph cruise). So to go 25km at that power consumption would be 25 * 20, or 500wh. SInce many batteries are rated in Ah instead of Wh, that's 500wh / 36v = 13.9Ah.
At a guess, this is likely to cost between $250-$500 for a good one; you may find ones half that price or less, but I don't know how good they will be. You might get by with as little as 7-8Ah, depending on how you use the bike, and so it will cost that much less.
Some random examples of styles (I don't have any recommendations yet):
https://www.amazon.com/BAFANG-Electric-Bicycles-Battery-250W-500W/dp/B07VGRWNXV
https://www.amazon.com/36v-ebike-battery/s?k=36v+ebike+battery
I recommend one that comes with a frame mount that you bolt or clamp to the bike and slide the battery casing into, so that you can take the battery off the bike with you when you aren't with it (it should make the bike less of a theft target without the battery, and if you do lose the bike you at least have a battery for the next one), and can take it inside for charging too. These things are essentially never waterproof, so keeping them out of the rain is a good idea.
If you prefer to carry it in a backpack (they're kinda heavy, so most poeple don't want to do this) with a longer cable to the bike, you can use the brick kind, often just shrinkwrapped in blue, and definitely not waterproof.
They can also be mounted on the bike but they're harder to make so that you can take them off easily.
If you need to go faster than that by motor power, then you can use a 48v battery, and that will probably reach 30-32kmh, maybe more. Depends on the motor winding and the controller power you have available, and the conditions (wind, hills, weight).
Since it will take more power to go faster, then you may need a slightly higher capacity battery (in Wh) to get the same range.
