Hi guys,
I got a 10S 5000mAh (2x[5S 5000mAh](http://www.hobbyking.com/hobbyking/store/__35809__ZIPPY_Flightmax_5000mAh_5S1P_20C_EU_Warehouse_.html)) and i would like to add a BMS on my board to make the recharging easier.
My motor is the APS 6374 170kv 3200W. If my motor is at is power max, i got 86A in the BMS (my weight is 200lbs).
So should i choose a BMS with the ability to reach 100A continious charge or a 60A will be enough because we will almost never reach this full power ?
I was thinking about to take this model : http://www.batterysupports.com/36v-37v-42v-10s-60a-10x-36v-lithium-ion-lipolymer-battery-bms-p-267.html what do you think about it ? Not too cheap ?
I found a lot of tuto for BMS cabling with home-made 10S3P but never with classical battery. Do you guys have a link to be sure to do well the cabling of the balance part ?
Thanks !
Thanks !
