Ok, one of the reasons I was wondering about this issue, is that I have one of those hydroplane boats I want to play around with. Right now, I'm not looking for out of this world performance, but I do want to get it in the water and start experimenting with it. The prop for my white one comes straight up and the original ice motor just slides right over the shaft. I was trying to figure out a way to couple that shaft with the turnigy shaft. I actually just took my cordless power drill and attched the chuck to the prop shaft and hit the trigger. I got it to spin the prop. So I was trying to figure out a way to do something like that between the two shafts. But once I got the motor, it seems like the shafts are real close to being the same size, so it kinda popped in my head that I had seen somewhere that you could just change the shaft. (I guess I was thinking of that go kart video.) So, I'm thinking that I can just take out the turnigy shaft, and attach the motor to the prop shaft. I will have to verify that they are the same size, but I just wanted to see if it was even possible before I started taking the motor apart. Next time I get back to the shop I will measure the prop shaft size. The one thing about the prop shaft though, is that it is slightly square. It has four sides that got flat spots, but the corners are still slightly rounded. If the diameter from corner to corner is the same, would this type of shaft work in the turnigy?
If this works, I get a bunch of lipo for this build and go play around. If it does work out and show promise, I hope to then maybe modify the prop shaft and stack a few turnigy's straight up from the prop.
