White Industries Tandom Hub
comradegerry
Afloat somewhere sunny
I saw this at prowheelbuilder and thought it might be of interest to some on the forum, especially the wide disc hub compatible version. Would it work for motor driven freewheel on threads, peddle power through a freewheel 9 speed cassette? Just a thought..... $250 blurb below.
Gerard
Our Daisy hubset is uniquely and distictively designed for tandems. The Daisy hub shells are engineered with flanges that are both elegant and taller than most hubs of yesteryear, and, yet, the taller flanges serve a specific purpose. A wheel that is laced to a high flanged hub such as the Daisy will into a stronger and stiffer wheel. Due to the load demans of tandems, additional strength is required at the wheels, and if coupled with a deep dish rim, the wheel will perform extremely well. The rear hub is drum brake compatible. Additionally, for frames with 145 mm spcaed triangles we offer a custom M16 disc tandem hub.
