Whyte T129 TSDZ2 conversion
Alfie
1 W
Yorkshire, UK
Here are some pics of my Whyte T129 TSDZ2 conversion.
This is it in commuter mode with road tyres. As soon as the rain stops here those mudguards will be gone and the Knobblies will be back on.
48v 500w, weighs in at 20.5kg, running custom firmware. I have two battery options at the moment, 8 and 12ah, both fit securely in frame bags. I did have to reverse the shock to get the battery packs to fit and added the wide narrow chainring. The drive side crank was also changed for a straight Bafang version. Other than that everything else is standard.
You should be very proud, beautiful looking ebike!! And I know that TSDZ2 has a great performance on such a bicycle :)
Thank you for the compliment and all the hard work you have done with the firmware. It is very much appreciated :wink: :wink: :wink:
Good choice the Whyte T129's.
Anybody else considering the later Whyte T130's or G series, sorry the rear suspension lower mount was widened and it puts the chainline in the incorrect position.
