I'd like to add a battery and give 48 volts a try. My motor and controller can handle 48v. I realize I could just cut the 36 volt throttle wire and do without the LED lights and the throttle should still function ok, but I hate to do that if I don't have to. That light is my reminder to be sure to turn the key switch off and if the throttle lights will work at 48v without damaging anything, I'd like to keep it. I realize the "low battery" light won't work at 48 volts, but I don't really care about that. Heck, with SLA batteries, you can definitely feel when you are about out of juice.
I found a few mentions in old threads that overvolting will damage the throttle and possibly other components, but it wasn't clear whether the posters who had experienced the problem had possibly overvolted all the way up to 72 volts rather than just to 48. Does anyone know whether these inexpensive 36 volt LED throttles can usually handle going to 48 volts without cutting the wires or adding other electrical parts?
