SonNguyen04
10 µW
- Joined
- Aug 17, 2015
- Messages
- 5
Last week I put a BBS02 into a Giant ATX 2. The unit slid in perfectly and installation was very easy. I am planning to buy this bike for my wife. http://www.bikesdirect.com/products/motobecane/29er-mountain-bikes/fantom29comp-tcs-xvi.htm My only concern is if the BBS02 will fit into the bottom bracket. I have heard stories about people buying a reamer kit to open up the bottom bracket. I really dont want to do that. Does ES foresee any problems I might encounter with this set up? Also the reason I am getting it off of BD and not a LBS is because the most important thing to my wife is bike color. She wants a white one. I have checked all the LBS and the white bikes that they carry are either too expensive or of way lesser quality.
Frame NEW Tapered Headtubes. MOTO29HX Kinesis Engineered Aluminum with TrailTuned PowerStay Design, DualProfile Hydroformed Downtube with reinforced Gusset, replaceable rear derailleur hanger, downtube bottle mount, seat tube accessory mount
Fork Rock Shox XC30 / TK29" / 100mm / Remote Lockout 1.125" Steerer
Crankset FSA GammaDrive MegaExo, 42/32/24T ALLOY BLACK CRANK 170/175mm: 33-39/44-53CM
Bottom Bracket FSA BB-1000
Pedals VP MTB Platform 9/16" CR-MO AXLE, BLACK PP BODY, STEEL BLK CAGE
Front Derailleur SHIMANO, FD-M610, DEORE, TOP-SWING, DUAL-PULL,BAND TYPE(W/31.8MM ADAPTER)
Rear Derailleur SHIMANO, RD-M670, SLX SGS 10-SPEED TOP-NORMAL SHADOW DESIGN
Shifters SHIMANO SHIFT LEVER, SL-M610, DEORE
Cassette/Freewheel SHIMANO CASSETTE, CS-HG50-10,10-SPEED 11-13-15-17-19-21-24-28-32-36T
Chain KMC X10SL NARROW CN 1/2"x11/128"x114L.W/HOLLOW PIN, REUSEABLE LINK
Hubs F/HUB GRAVITY LASER-ETCHED ALLOY DISC BLK ANOD. FRONT HUB W/RCC,W/RLCA ALLOY BLK QR, 14Gx32H:100mm
R/HUB GRAVITY LASER-ETCHED REAR BLK ANOD. CASSETTE DISCBRAKE W/RCC HUB , W/RLCA ALLOY BLK QR 14Gx32H:135MM
Spokes 14Gx64PCS STAINLESS W/14mm BRASS NIPPLE
Rims Tubeless Compatible, WTB Frequency Race i25 TCS 29" 32 hole, Disc, Black; I-Beam Construction, 4D Drilling, PV drilled
Tires WTB Bronson 29x2.2 Comp With PV Tube ,( 52/56 ) 27tpi Casing, Wire Bead
Brakes SRAM GUIDE R, HYDRAULIC DISC, POST DISC MOUNT, 180mm CL1 ROTOR, Gloss Black
Brake Levers SRAM GUIDE R
Headset ORBIT 1.5 ZS , FOR 1-1/8"/1.5" FORK STEM , Internal alloy cups, ACB 1-1/8" Upper, 1-1/8" crown race,w/Std 12.3mm top cover, W/30mm BALL RACE ( 28.6x44/55.95x30mm) (H:19.8 mm )
Handlebar RITCHEY MTN RIZER ( C:31.8mm ), ALLOY 6061 RISE H/BAR(UPSWEEP 17° , BEND 9° ) B/CENTER: 31.8mm.R/W:20/670mm. BB BLK
Stem RITCHEY STEM 4-Axis 84/6D ( C:31.8mm ) ALLOY 6061 "TIOGA-OS" A-HEAD STEM.EXT6°)110MM ,C/S:31.8x28.6x42mm. BB BLK
Tape/Grip WTB Dual DNA Compounds, Classic Logo Pattern, full length
Saddle WTB Speed V Sport SE
Seat Post RITCHEY 2BOLT, ALLOY BB BLK 27.2x400mm
Seat Post Clamp Superlight Aluminum (31.9x30.5) W/CR-MO ALLEN BOLT
