billvon said:
Rubbish. ! The (IPCC) “models” predicted much higher warming than has been recorded ( Data,..not alarmist news clip headlines )
Let's look at some of those predictions.
FAR, 1990 - predicted 1C warming 1970-2016, with an increase in CO2 to 418ppm. Actual numbers were .85C with an increase in CO2 to 404ppm. So the CO2 increase was less than predicted, and the actual warming was 17% less.
Considering the first 20 years of that period were already recorded in 1990, that was not a prediction .
What 1990 IPCC FAR: actually predicted was.. “Under the IPCC ‘Business as Usual’ emissions of greenhouse gases … this will result in a likely increase in global mean temperature of about 1°C above the present (1990) value by 2025.” (See , page xi.)
The actual result..
From 1990 to 2017 (first 8 months) the increase in temperatures was 0.31 to 0.49°C depending on the database used. CO2 emissions have tracked the Business as Usual scenario.
It also predicted a rate of increase of 0.3 C per decade, with a range of uncertainty between 0.2 to 0.5 deg C.
The actual rate to date has been between 0.12 and 0.19 C, (depending on which data set you prefer)
Either way, the actual data is way below even the lowest FAR predicted range
TAR, 2001 - predicted 1970-2016 temperature change accurately within 14%.
AR4, 2007 - predicted 1970-2016 temperature change accurately within 8%.
So, they didnt even accurately “predict” 30 & 37 years of already known results !
:lol: :lol:
...Pretty damn good, overall.
you are easily impressed..and fooled !
97% of scientists agree !
Well, between actually 97% and 100% of climate scientists depending on how you phrase the question and run the tests. And if you include people whose livelihood depends on not understanding climate change (like, say, petrochemical engineers) that number starts dropping fast.
Specifically:
Oreskes, 2004 - 928 climate change papers surveyed; none rejected the basics of AGW (0% rejection.)
Doran & Zimmerman, 2009 - asked in survey of earth scientists "Do you think human activity is a significant contributing factor in changing mean global temperatures?" 82% of all respondents said yes. When narrowed down to active climate researchers that rose to 97%.
Anderegg, 2010 - reviewed publicly signed declarations by climate change experts. 97% consensus.
Cook, 2013 - 4000 climate change papers surveyed; 97.1% endorsed AGW.Anderegg
Why do you keep regurgitating this rubbish ??
All of those have been thoroughly disected and debunked...multiple times..
From memory..
Oreskes...zero rejections does not mean everyone agreed ! That is junk research !
D& Z..their “97%” result was actually just
77 responses from 80 selected scientists.
Anderegg.. was a “google search” survey and only reflects 200 results
Cook..
... Cook had created a category called “explicit endorsement without quantification”—that is, papers in which the author, by Cook’s admission, did not say whether 1 percent or 50 percent or 100 percent of the warming was caused by man. He had also created a category called “implicit endorsement,” for papers that imply (but don’t say) that there is some man-made global warming and don’t quantify it. In other words, he created two categories that he labeled as endorsing a view that they most certainly didn’t.
Just one of many rebuttals of Cooks amateurish work.!
In other words... the 97% reference is a joke.
A quote from Swedish Climate scientist who has chair of the IPCC panel for sea level rise..
“ 97% of scientists may agree with AGW theory,...but 97% of SCIENCE does not. ! :wink:
