donob08
Hey
..I ride 15 or so miles a day in this glorious weather near Rochester, NY. The residents here are feeling bad because we are are third in the state's snow competition, only 50 some inches so far. You Canadian guys have all the luck.
.. I ride a somewhat modified Currie eZip Trailz with a 24V 15 AmpHr Ping LiFePO4 battery pack. The motor, controller, battery et al have been happy as clams so far (knock wood). But the cable to my back linear brake tends to freeze up.
.. After a few hours of leaving the bike out somewhere on my rounds I come back to find the brake cable frozen in its housing. Normal force on the brake lever won't move it. And if I use mundo force the caliper closes on the rim but the spring force wont pull the pads away when the lever is released. Stuck ON back brakes is a BAD thing. So I don't use the back brakes.
..Using front brakes alone on an icey road is not really advisable either. I can finese it unless a light changes on me unexpectadly and I have to make a quick stop. That can/has led to minor disaster.
..So my question is: How do you stop H20 from getting in the cable housing? I have taken the bike inside, thawed it out and "treated" the housing. My treatment is to use "lock deicer" to get the gunk out of the housing, WD40 as a further cleanser, a glob of light grease around the cable at the top ends of the two sections of housing.
..Ideally, when I apply the brakes, the glob should move away from the top of the housing with the cable and then when the cable is released it should go back down to seal the top of the cable. That seems to work for a while. But apparently after a while, water still finds its way in, and later on freezes, leading to a chance to polish the ice with my butt.
..Any ideas?
..Any ideas?
