Wobbly wheel on axel, what size bearing voilamart 1000watt
chrisvoi
Manchester
I was wondering whether someone would know the correct size bearings I would need for my hub motor, as it slightly rocks side to side , ( feels like just non drive side ) but wanting to change both sides but without dismantling the whole thing to measure the axel bearings, just to build it back again as I have to use for work travel , I don't want this matter to get worse , but the wheel has served me real well at 8k miles and still healthy strong pull, I only really notice this wobble when hitting a kerb, or just general moving around slowly,,,, plz help ???
Bearings usually have two seals (usually black). Look closely at the seal, should be a number (i.e. 62xx, 63xx, ect) then compare it with the chart below:
No seals?... then measure OD, ID and width with caliper and simply match by size.
Have you searched around? Something like "voilamart 1000watt axle bearing size?"
Did you contact the vendor or mfr?
If you did with no results, and nobody answers here you will have to closely inspect or measure as Papa suggests above.
I've been answered on another forum sorry I think y'all misunderstood, the size is 6202 sealed ?? Easy to obtain I've been told, no I havnt been answered from the vendor or other manufacturers, I simply thought someone out there would of changed the bearings on one these things , sorry I just lazy I didn't want to open the dam thing to measure them to build back up so I could use for work whilst theyre in the post ,, thanx you anyway
