i am in the process of designing a construction and material app for wood bicycle.... the material will be baltic birch and red oak..baltic birch is a hardwood ply, very strong and dimensionaly stable..also reasonablt priced..a 60"x60"x1/2 shett is only $32.00..about 2/3 of aq sheet is enough.. the oak will be drilled for steering tube,bottom bracket and seat post.... a frontsteel suspension fork will be used... the frame is two matching sides joined by the oak... the red oak will also be usewd to trim the ply edges... it will be possible to design almost any shape of bicycle form..e.g, chopper,lowrider,mtb ,ect.... not very heavy...the lowrider frame i am currently working on will weigh about 20lbs max... disc brake caliper can be bolted onto the wood fork... the crrent design calls for Cyclone motor. Nuvinci hub,Lyen controller and lipo battery..when i get down to actual construction i will post some pictures
