Hi Folks,
I have a problem that I hope your expertise will help me solve...
First, I have an X-treme XB-508. I've never had a problem with it, reliable as all get-out.
I had my back-up battery pack in it yesterday (I have two for those days when I run a lot of errands). To make it easier to swap out batt-packs, I connected the terminals with simple slide-on connectors. While I was riding yesterday, the vibration caused one of the connectors to slide off one of the batteries and I lost power. This has happened a couple times in the past but I had just reconnected the one terminal and away I went. Yesterday was not the same... I connected the terminal, all was fine... I start up and less than 5 seconds later it just died. Crap!
I decide to push it the 4 blocks to my house. Here is the weird thing... As I pushed the bike there was this weird heavy pulsing resistance as the rear wheel rotated. What the heck? I disconnected the battery pack at the plug in the battery box and I put it up on the center stand to take a look... no resistance turning the wheel backwards but that same hard pulse type resistance rotating forward.
I had no other way to get it home so I pushed it the four blocks to my house. It was pretty hard because of that resistance in the rear wheel. I did try to pedal it but the resistance made that impossible.
When I got home, I checked the in-line 30 amp blade fuse and sure enough it is fried. I replaced the fuse, connect the battery pack, turn key on... Zap! Thunk in hub-motor! Fuse fried. Rear wheel started to turn for less than a second and there was a thunk sound from the rear wheel at the same moment. It was so hot in the fuse holder that it melted part of the metal connectors inside. Hmmmm? Out of curiosity, I rotate the rear wheel and now there is no resistance either rotating forward or backward. I tried hooking it up again and got the thunk/ burnt fuse again. Wheel also developed that strange pulsing resistance when I rotated it again manually.
I am pretty lame when it comes to complicated electronics. I can wire a house, I can tune a '60 Chevy but stuff like this and electronic theory boggles my mind.
So this is where I am at:
I disassembled the rear wheel/hub-motor and found that the center part(hub ?) was magnetized to the surrounding metal plates on the rim part. It took some doing and a fair amount of force but I got the center part out. I examined it but couldn't see anything burnt or discolored. I had it apart for about a day and when I reassembled it, there was no further magnetic effect and the wheel spun freely on it's axle. I put the wheel back in the bike, connected all wires except the three heavy motor wires, all 12 volt circuits work, I disconnect the batteries, connect the motor wires, reconnect the batteries, ZAP!, it actually burnt the heavy gauge metal prongs inside the battery pack-to-bike plug.
I have replaced the 30 amp inline fuse holder, the batter pack-to-bike connectors.
With all wires connected it constantly burns the 30 amp fuse.
With heavy gauge hub-motor power wires disconnected from the controller I can turn the key on and have power to all lights, horn, etc. and the fuse does not burn up. As soon as I connect the hub-motor I get a burned fuse, the hub-motor will sometimes "thunk" inside and now has that strange pulsing resistance when rotated manually.
It appears that the controller is working correctly and there is something very wrong inside the rear wheel hub-motor.
I have ordered a new controller and am waiting for that.
Whatcha think? Any ideas? If it's not the controller, what else do you think it could be?
Thank you in advance.
