maresia
New here
Hello, English is not my first language, and I have a sensorless geared hub motor that is spinning inside the wheel, but the wheel itself isn't turning. I searched for solutions on the internet, and the two main actions I observed were "investigating the planetary gear" and "swapping the motor phases as it might be spinning in reverse." I tried all 6 combinations, using the learning wires to reverse the motor direction, but it didn't work.
I replaced the 3 gears that were a bit old, but it didn't help. When I turn the wheel, the magnets rotate in the opposite direction, indicating there's contact between the gears. However, when I spin the magnets with my fingertips, I don't feel the resistance that would normally make the wheel turn in the opposite direction.
When the motor is spinning backwards, the wheel spins perfectly, but in the opposite direction of what I want.
The videos are available in the links below:
hub motor 5
